o2 sensor?
Old Jul 23, 2003 | 10:19 PM
ProJectCvic's Avatar
Default o2 sensor?
are all civic and integra o2 sensor the same? i would like to use my civic dx o2 sensor in my ls obd1 swap.
Old Jul 24, 2003 | 03:57 AM
VTECVillain's Avatar
Default Re: o2 sensor? (ProJectCvic)
As long as you are matching the style of O2 sensor used to the ECU of the Integra that uses the same type of O2 then you'll be fine. An OBDI LS ECU will look for a standard 4 wire O2, so if you have an OBDI DX 4 wire O2 then you can reuse it.
Old Jul 24, 2003 | 07:48 AM
Default Re: o2 sensor? (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">As long as you are matching the style of O2 sensor used to the ECU of the Integra that uses the same type of O2 then you'll be fine. An OBDI LS ECU will look for a standard 4 wire O2, so if you have an OBDI DX 4 wire O2 then you can reuse it.</TD></TR></TABLE>
makes sense. Thank you
King V
Nov 30, 2007 04:40 AM
Se-rv-Tak
Nov 29, 2003 03:41 PM
gtpilot
Dec 12, 2002 12:27 PM
creuger
Nov 15, 2002 07:11 PM
