What is this black box on a 95 vx
Im putting a 92 b18a1 in a 95 vx theres this black box with a plug on it and 2 vac lines coming out of it...what is it?
paste the url in your explorer url bar.
http://swtracing.netfirms.com/...x.jpg
Re: What is this black box on a 95 vx (BVM)
pic dosent always work but heres the link to it.
also its the black box on the firewall.
Pic link doesn'w work but let me take a stab at it. If the one vacuum hose goes to the intake manifold and the other to the charcoal canister and it has a wires pluged into it then it's the evaporative purge system solinoid. It's about a one inch square box.
Re: What is this black box on a 95 vx (W.O.T.)
I am 99% sure the box you are refferering to is the controller for the EGR valve on the VX motor...its a black box attached to the firewall on the top middle and it is about three or so inches wide?...unless you are swapping in a H22A and need to use an EGR valve you can remove it...good luck!
Re: What is this black box on a 95 vx (1fastVX)
yeah top middle on the firewall. 3inchs long and high. thats what it is... thanks
b18-c-rx
07-02-2005 06:59 PM
