O2 sensor issues with a B16a1
Old Jul 14, 2003 | 03:16 PM
Wicked_CRX's Avatar
Default O2 sensor issues with a B16a1
I have a b16a1 swapped into a 90 CRX, anyone know if I need to use a CRX O2 sensor or will a b16a4 sensor work? I'm running the Sir ecu, any help would be appreciated.
Old Jul 14, 2003 | 04:52 PM
Katman's Avatar
Default Re: O2 sensor issues with a B16a1 (Wicked_CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wicked_CRX &raquo;</TD></TR><TR><TD CLASS="quote">I have a b16a1 swapped into a 90 CRX, anyone know if I need to use a CRX O2 sensor or will a b16a4 sensor work? I'm running the Sir ecu, any help would be appreciated.</TD></TR></TABLE>
unless you converted your car to OBD1, you can't use a B16A4 02 sensor (I assume it uses a 4-wire 02).
You can totally reuse your CRX 02 sensor.
Wildemanam
Honda CR-V & Element
Jan 30, 2018 08:58 AM
category5 SI
Jan 8, 2014 04:28 PM
Jebus
Mar 21, 2003 02:43 PM
mickey513
Jun 2, 2002 04:42 PM
CivicBoi
Mar 30, 2002 12:07 PM
