Got new b16 swap, What parts should I replace? OEM or Aftermarket?
I have heard that when you get a new (SIR 1) B16 you should get: water pump, timing belt, plugs, wires, cap and rotor, clutch, and tensioner pulley. What do you guys think? Should I go with oem honda or aftermarket stuff? What car should this stuff be for, since I can't say to the honda dealer that I have a jdm sir1 b16a. Please Help!
Re: Got new b16 swap, What parts should I replace? OEM or Aftermarket? (sdubswapper)
You can get Honda OEM stuff. From the B16A3 (94-94 del Sol VTEC) or the 99-00 Si (B16A2).
Re: Got new b16 swap, What parts should I replace? OEM or Aftermarket? (poison)
Water Pump 19200-P30-003 94 - del sol
Head Gasket 12251-P30-014 94 - del sol
Oil Control Orfice O ring 15142-PH3-003 94 - del sol
Intake Manifold Gasket 17105-P30-004 94 - del sol
Exhaust Manifold Gasket 18115-P30-013 94 - del sol
throttle Body Gasket 16176-PR3-010 90-91 integra
Pcv valve 17130-PM6-G01 94 - del sol
Timing Belt 14400-PR3-004 94 - del sol
Alternator Belt 31110-PR3-003 94 - del sol
Tensioner 14510-P30-003 94 - del sol
Thermostat 19301-P08-305 90-91 integra / 94 del sol (same)
Connecting Pipe O rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same)
Cap & Rotor Assembly 06303-PR4-000 90-91 integra
Rotor (If needed seperately) 30103-PR3-016 90-91 integra
Clutch Cable 22910-SK7-A02 90-91 integra
Throttle Cable 17910-SK7-A03 90-91 integra
Cam Seals (2) 91213-PR3-004 94 - del sol
Oil pan seal 11251-P30-004 94 - del sol
Oil Pump (comes with crank seal) 15100-PR3-024 94 - del sol
Oil Filter 15400-POH-305 94 - del sol
Oil Pick Up Gasket 15221-PW0-S01 94 - del sol
Bitch Pin Shift Linkage 91 crx si ???
Shift linkage bushing 54303-SB2-010 90-91 integra
crank seal 91212-PR3-003 94 - del sol
rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same)
Valve cover grommets (8) 90442-P30-000 94 - del sol
Spark Plug O rings (4) 12342-P66-000 94 - del sol
Rubber plug for exhaust cam tranny side 94 - del sol
Spark Plugs (4) BKR6E-N11 NGK
Spark Plug Wires 32722-PR4-A01 92 - integra gsr
Upper Radiator Hose 19501-PR3-000 92 - integra gsr
Lower Radiator Hose 19502-PR4-A00 90-91 integra
Bypass Hose (Thermostat) 19508-P08-000 94 - del sol
Washer for coolant drain on block 90401-PR4-000 94 - del sol
Re: Got new b16 swap, What parts should I replace? OEM or Aftermarket? (madeiniraq)
i replaced cap, rotor, plugs and wires.
Later on when i did my cams i replaced timing belt
replace what you can afford. I would say atleast the timing belt
bluecrxsi
22
02-25-2003 04:47 PM
Monty
09-07-2002 05:41 AM
