How do you wire up IAC
tape up the orange wire and get it out of the way because you won't use it. i assume you have an integra plug with two wires to use. on the integra plug, i believe people consider the side you press down on to disconnect the plug the top. connect the yellow/black wire from your harness to the wire on the "top" of the integra plug. connect the other two wires, tape it off, and you should be good to go.
you didn't give a lot of information about your swap but i am guessing you are putting a B-series in your DX. move A14 wire to A12 on the plug that connects to the ECU.
i have this set-up on mine and there is no CEL for the IACV now.
