Buying an LS motor.. Need Help
Ok, I am buying an LS motor for real cheap, but there's missing parts. I was hoping you guy could help me. I am just buying the motor itself. He said there's not ECU.
What all am I missing? ECU, Tranny, and?
I am swaping into an '00 Hatch. Could I use GSR motor mounts?
Re: Buying an LS motor.. Need Help (JDM CTR EK)
It's a '96 motor. I found a '00 Tranny. Would I need a '98-00 ECU (OBD2)? What shift linkage could I use?
Try and find a complete swap. it will probably end up being ALOT cheaper in the long run and save yourself alot of searching and problems.
Re: Buying an LS motor.. Need Help (POS Hatchback)
complete swap is much easier unless you have experience with swaps. Just some advise, find a GSR tranny instead of an LS
jpb105079
07-07-2004 11:21 AM
steveo97civic
01-23-2003 08:44 AM
