Axels ??? Need help
Old Jul 14, 2003 | 12:30 PM
2slo4me's Avatar
Default Axels ??? Need help
Well Im planning on doing a b18c1 swap into a civic .. Either hatch coupe sedan either or.. What type of axels should I be looking for ..? Would the GSr axels fit on the civic.?
Old Jul 14, 2003 | 12:46 PM
Newman's Avatar
New User
Default Re: Axels ??? Need help (spider69911)
Yes, they'll fit. Just make sure you get the appropriate intermediate shaft to go along with the axles and they'll bolt right up into your Civic hubs.
Old Jul 14, 2003 | 01:06 PM
poison's Avatar
Default Re: Axels ??? Need help (Newman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman &raquo;</TD></TR><TR><TD CLASS="quote">Yes, they'll fit. Just make sure you get the appropriate intermediate shaft to go along with the axles and they'll bolt right up into your Civic hubs.
Newman is the man
Old Jul 15, 2003 | 04:16 AM
2slo4me's Avatar
Default Re: Axels ??? Need help (poison)
where can I find some sort of axels for the civic that is durable for the b18c1 block ?? any sites or anything ..? and what type is the good enough .? or can I just go OEM gsr axels
Old Jul 15, 2003 | 06:00 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Any 1994-2001 Integra axles will work fine. Also 99-00 Civic si axles and 1994-1997 Del Sol VTEC axles will work as well.
I see that you said that you mentioned a 4-door, so does it have ABS? Some 4-doors, EX coupes, and Si hatches came with ABS so make sure before you buy axles what type of car you have.
If you car doesn't have ABS then you can get either ABS or non-ABS axles and it won't make a difference in how they fit. ABS axles usually cost $10.00 more because of the ABS ring on them.
If your car has ABS then of course ask for ABS model axles.
Remember, the axles do not have to be for a GS-R specifically.
As far as where to get them goes, try any parts store that offers lifetime warranties like NAPA, Auto Zone, Advance, etc.
I'm currently running NAPA CCT axles which I've broken the right one once, but it was 1005 FREE to replace since i do my own labor.
woodenchef
Dec 24, 2012 11:55 AM
importkidd
Apr 4, 2006 02:12 PM
handa
Jun 14, 2005 09:00 PM
hxtasy
Feb 22, 2005 06:38 AM
eL
Jan 15, 2005 08:20 AM
