Any EF's using a OBD1 B16 ?
Old Jul 15, 2003 | 02:31 PM
7PSiEF9ZC's Avatar
Default Any EF's using a OBD1 B16 ?
O.K. Since I'm buying the motor tomorrow I'm posting this in as many places as possible since I need info ASAP Thanks to all that help me.After blowing my turbo ZC motor I'm done with D series and ZC's and I'm getting ready to go pick up my B16 tomorrow. Here's the thing I have two choices. One get a OBD0 B16 or get a OBD1 B16 ( have to change over the Dizzy , injectors , and ECU ). The Company I'm getting the motor from said if he sells me a OBD1 B16 and he'll change over the dizzy , and ECU ( I'm just gonna use my old ZC injectors since they're the same as B16's ). Now will using a OBD1 B16 on a OBD0 ECU throw any false or funny codes as long as I switch everything over that needs to be. Also I'd like to use the OBD1 since it has 10 more HP and is supposely alittle better because of it. Cost isn't a issue since I have more then enough to cover either one ( the obd0 being alittle cheaper ). Just curious since I don't want to get stuck with a motor that I have to switch a bunch of things around. Just the injectors , Dizzy ( distributer ) , and ECU is fine with me unless there's something else I'm forgetting.
Old Jul 15, 2003 | 09:33 PM
dot this Promo's Avatar
Default Re: Any EF's using a OBD1 B16 ? (7PSiEF9ZC)
i hope u bought the first gen b/c if went 2nd u need to do wire to obd1 .
aboobybobpleez
Jul 29, 2008 08:26 PM
Stray
12
Jul 17, 2007 04:20 PM
7PSiEF9ZC
Jul 17, 2003 06:21 PM
7PSiEF9ZC
Jul 16, 2003 09:37 AM
