K20 into EG....PS & AC removal...searched
I was wondering if removal of the power steering and AC on a K20 is the same as a B-series, D-series, etc. I ask this because I saw the Evolution PS & AC removal kit and found it to be a waste of money if the removal is the same as older motors, remove belt and remove part right?? Tried searching for it didn't find anything useful. Thanks guys
Re: K20 into EG....PS & AC removal...searched (eXcelonTypeR)
Visit http://www.k20a.org for all of your k-series swap questions/information!
PS & AC removal is a breeze w/ the K motors. You just run a non-PS EP3 idler pulley, rip off the AC compressor, and slap on a 50.5" long 7 rib belt...
Modified by Karcepts at 6:09 AM 7/16/2005
Re: K20 into EG....PS & AC removal...searched (Karcepts)
I was looking around there, posted there a few times but didnt get any info pertaining to this, but they are helpful there thou.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eXcelonTypeR »</TD></TR><TR><TD CLASS="quote">I was looking around there, posted there a few times but didnt get any info pertaining to this, but they are helpful there thou.</TD></TR></TABLE>
If they weren't able to post any info to your question, it might have been because there have been so many threads on the subject previously. Just searching for "belt" on k20a.org comes up w/ a few...
http://www.k20a.org/forum/show...=belt
http://www.k20a.org!!!
Good luck with that swap!
This may help you out..
31190-PRA-000 PULLEY, IDLE
31175-PRA-000 BRACKET, IDLE PULLEY
31185-PCX-003 COVER, BEARING
90031-PRA-000 BOLT, SPECIAL FLANGE (10X25)
Dayco Belt 5070505... 50.5 inch belt
Good Luck..
Good Luck..
The Evolution kit is a really nice piece. Easy to bolt on and allows you to retain the original RSX Belt.
You can also get a light weight cranky pully made by them as well.
Re: K20 into EG....PS & AC removal...searched (Goatsterrman)
Ahh cool cool, didnt know that....their website is still under construction so its hard to get info just srufing around....but thats for the info
i have seen the Evolution Kit in person and its really nive. they took the time to make it perfect and missed nothing
1 Post
I had the PS pulley machined to slip on the alternator and spaced it out with washers, longer bolts. Fits great, we will see if double the size pulley affects alternator power output(should cut it in half)...
95EXcivicsleeper
04-25-2004 10:43 AM
