LS/Vtec Swap Help!!!!
Old Jul 10, 2005 | 09:07 AM
dc9turbo's Avatar
Default LS/Vtec Swap Help!!!!
Im in the process of doing an ls/vtec swap. i heard something about having to make the dowels for the head bolts bigger by drilling them out..... is this true and how would i go about doing this???
Old Jul 11, 2005 | 06:03 AM
iakona's Avatar
you can also buy any readily available ls/vtec kit that will supply you with everything you need : head gasket, oil line, dowels, etc.
Old Jul 11, 2005 | 06:33 AM
Db1_77's Avatar
Default Re: (iakona)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iakona &raquo;</TD></TR><TR><TD CLASS="quote">you can also buy any readily available ls/vtec kit that will supply you with everything you need : head gasket, oil line, dowels, etc.</TD></TR></TABLE>
YES!!
Old Jul 11, 2005 | 04:24 PM
dohcdelsol93's Avatar
Default Re: (hatch77)
Get the golden eagle kit. It includes the head gasket, the dowel pins, all hardware, oil feed line, pancake for the oil feed/oil filter, and even the tap for blocking off the oil feed in the head.
Old Jul 11, 2005 | 04:31 PM
VTECVillain's Avatar
Default Re: (dohcdelsol93)
If you've already got the oil lines, NPT plug, etc. you can also buy the dowel pins and modified headgasket separately. The tapered dowels makes the procedure a whole lot easier too.
Old Jul 13, 2005 | 03:14 PM
dc9turbo's Avatar
Default Re: (VTECVillain)
u guys are geniuses!!!! now a good site to get the kit for cheap?
Old Jul 13, 2005 | 04:18 PM
iakona's Avatar
check the sponsor forum. GE is there and they have a special going on right now.
Old Jul 13, 2005 | 04:48 PM
dc9turbo's Avatar
last ques.....im going to use a itr tranny on my teg with the ls/vtec swap....what #'s should i expect if i use a safc to tune the setup (boost is i the near future)
egzo04
Dec 19, 2006 12:42 AM
NAlover
Aug 12, 2006 01:52 PM
0554
Jul 12, 2005 05:54 AM
kerby116
Feb 29, 2004 05:33 AM
92gs-r
Mar 19, 2002 05:59 PM
