Accord V-tech Head Swap
GDD Member
Yes, it's possible. Browse the civic forums and read up on mini-me swaps. Same process, bigger head.
Edit: You'll need to use the injectors that came stock in the car you're swapping into, and if it's going into a 92 accord, you need to use the 94-95 EX ECU, if in a 90-91 Accord, use a WOT or RPM activated VTEC switch with the stock ECU.
Ditto
Re: (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM »</TD></TR><TR><TD CLASS="quote">the 90-92 vtech's were 15 channel, and the 99 up vtech's are either 900 mhz or 2.4 ghz, so I'm predicting problems while swapping the antennas.</TD></TR></TABLE>
Hasport mounts are great here. HCP mounts will work, but they kinda place the antenna a little lower than I would like it.
helpmeplease
03-29-2008 05:17 PM
