OBD0-1 conversion , Ign. Timing Adj. Connector?
I´m done with a OBD0-1 conversion on my 89 CRX. Everything is working correctly with no codes, however I´m unable to find out where the Ign. Timing Adj. Connector is located on a OBD1 ECU. On the OBD0 ECU it´s located at pin B20 according to this link : http://www.hondaswap.com/forum...29360
Can anyone tell me where this is located on a OBD1 ECU ?
Re: OBD0-1 conversion , Ign. Timing Adj. Connector? (Arvid)
my man i got a dilemma do u by any chance have the instructions for ur obd0 to 0bd1 harness instructions cuz i lost mine and thats all i need to finisch my conversion i would appreciated if u can send me a copy of them thanks man
Re: OBD0-1 conversion , Ign. Timing Adj. Connector? (curioso)
I don´t have the instructions , my conversion harness didn´t come with any. However if you use the ECU pinouts located here http://tech2.hybridgarage.com/..._obd1 and here http://www.hondaswap.com/forum...29360 you should have all the info you need.
As to my original question , I read some more in my helms manual and it seems to me that I should jump the connector that I use for checking codes to set the ignition timing. Is this correct ?
hope this helps man, http://www.hondaswap.com/forum...29360
link
let me know ifit did thanks for the info
link
Tensa_Zangetsu
23
11-23-2008 08:09 PM
prionailurus
03-25-2008 12:28 AM
