H22 swap..Accord 91 shifter cables and assembly in 97 hatchback will it work..??
swapping in an h22 in a 97 hatch..Will the cables and assembly from a 91 accord work for this swap?..thanks
New User
Re: H22 swap..Accord 91 shifter cables and assembly in 97 hatchback will it work..?? (Treblarefils)
yes
PM me if you have anyquestions, Ihave the same swap in my hatch
Re: H22 swap..Accord 91 shifter cables and assembly in 97 hatchback will it work..?? (BigBlockCRX)
cool man..My friend has an old crappy accord that we are going to take the parts from but were curious as to if it would work for sure..less stuff to buy this way. Motor is already in..
Yup, you can use 90-93 accord shifter assembly and linkage for that swap.
Re: H22 swap..Accord 91 shifter cables and assembly in 97 hatchback will it work..?? (simon98h22)
thats also what i used originally... eventually i switched over to a 94 prelude assembly when i could find one for cheap. It will sit about 1/2" lower and shift noticably faster, but the accord one definitely did the trick in the man time
VtecSickness
07-17-2009 11:35 AM
