H22A engine swap. Wrong Ecu?
Old Jul 4, 2005 | 09:09 AM
lak8's Avatar
Default H22A engine swap. Wrong Ecu?
I Just got my h22a 5spd engine swap today every thing looks pretty good but i noticed the ecu might be for a auto tranny?...
Here are some pictures i took of the ecu. Would this still work with my swap or should i ask them to exchange it.
Old Jul 4, 2005 | 11:05 AM
Slavko's Avatar
Default Re: H22A engine swap. Wrong Ecu? (lak8)
If you look on the sticker it says p13. That means its a obd1 h22 ecu.
Old Jul 4, 2005 | 11:22 AM
SixguN's Avatar
Default Re: H22A engine swap. Wrong Ecu? (Slavko)
It says its converted to 5-speed so you shouldn't have a problem. It originally is a automatic though. Its a JDM ecu. It has a speed limiter that kicks in at about 119.
Old Jul 4, 2005 | 12:16 PM
MrMike's Avatar
Default Re: H22A engine swap. Wrong Ecu? (Sixgundone)
i remember the limiter being lower then 119. i remember if u downshift to 4th u can still go faster. anyways i think thats kinda shady that they gave u a converted ecu instead of a 5speed to begin with. where u buy the swap from?
Old Jul 4, 2005 | 12:44 PM
lak8's Avatar
i bought it from tiger japanese auto parts in toronto. (im in canada)
Every thing else on the engine looks pretty good inspt for this and the downpipe/o2 sensor
Ill probably ask them if i could send these parts back and see if they give me a new one. i mean i did pay for a manual ecu so i dont see why not
Old Jul 4, 2005 | 12:47 PM
SixguN's Avatar
Default Re: H22A engine swap. Wrong Ecu? (MrMike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrMike &raquo;</TD></TR><TR><TD CLASS="quote">i remember the limiter being lower then 119. i remember if u downshift to 4th u can still go faster. anyways i think thats kinda shady that they gave u a converted ecu instead of a 5speed to begin with. where u buy the swap from?</TD></TR></TABLE>
Yea, that is kinda shady. I wanna know were u got it too. Also, I have the same ecu as him, but its not converted. I need to get rid of it, or get it converted.
Old Jul 4, 2005 | 01:04 PM
under_psi's Avatar
my buddy does all the chipping/ecu conversions for tiger japanese. the ecu should be fine. open it up and see if it is socketed/chipped, might be.
what's so shady about a converted ecu from auto to 5spd? sometimes that is all that is available and we use them all the time with no problems. Not trying to stand up for tiger cause ALL JDM importers try to pull fast ones from time to time, doesn't matter who you deal with or how many times you deal with them. you just have to know your **** and know what you're looking at.
good luck...
Old Jul 5, 2005 | 05:44 AM
RotiEatter's Avatar
Ditto
Default Re: H22A engine swap. Wrong Ecu? (T.O.tegs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T.O.tegs &raquo;</TD></TR><TR><TD CLASS="quote">my buddy does all the chipping/ecu conversions for tiger japanese. the ecu should be fine. open it up and see if it is socketed/chipped, might be.
good luck...</TD></TR></TABLE>
It's only shady because they didn't inform him of this.
If I buy a brand new blue Civic, I would it to be blue... I would not want one that was originally black and repainted to blue.
Old Jul 5, 2005 | 10:14 AM
SixguN's Avatar
Default Re: H22A engine swap. Wrong Ecu? (RotiEatter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotiEatter &raquo;</TD></TR><TR><TD CLASS="quote">
If I buy a brand new blue Civic, I would it to be blue... I would not want one that was originally black and repainted to blue.</TD></TR></TABLE>
Exactly
Old Jul 5, 2005 | 07:38 PM
Newman's Avatar
New User
Depending on what ECU program you use, some won't get rid of the code 30 that you'll get because of the 4ws plug. Just watch out for that.
Old Jul 5, 2005 | 07:49 PM
SixguN's Avatar
Default Re: H22A engine swap. Wrong Ecu? (Newman)
I have that same ecu. Some tell me the converting to manual is simple, others say its not. Is it something I can do in my own time?
Old Jul 6, 2005 | 05:40 AM
HavokB18's Avatar
since when do obd1 ecus have 4 sets of pinouts? or do i need to go put my contacts in?
Old Jul 6, 2005 | 08:34 AM
under_psi's Avatar
Default Re: (HavokB18)
it's an OBD1 ecu just one extra plug due to the 4ws. only a 4ws obd1 ecu will have the four plugs. OBD2 4 plug ecus use different shaped plugs/layout of the pins.
Old Jul 6, 2005 | 11:06 AM
Forrest Gump 9's Avatar
Default Re: (T.O.tegs)
Idon't think it's OBDI either. I have a USDM p13. It had 3 plugs, and all the pins are in the same row, not stager like in the pic.
Old Jul 6, 2005 | 11:54 PM
94_HATCH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HavokB18 &raquo;</TD></TR><TR><TD CLASS="quote">since when do obd1 ecus have 4 sets of pinouts? or do i need to go put my contacts in?</TD></TR></TABLE>
You need to put your contacts in to help you READ better. Its a JDM P13, not USDM. Like 3 other people already said the 4th plug is for 4ws.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo9Nut &raquo;</TD></TR><TR><TD CLASS="quote">Idon't think it's OBDI either. I have a USDM p13. It had 3 plugs, and all the pins are in the same row, not stager like in the pic.</TD></TR></TABLE>
Read my above post genius.
To the original poster i would just open it and see if its been converted or not. If not just ask the company you bought it from if they could send you and "original" 5 speed ecu and call it a day good luck
Old Jul 7, 2005 | 12:30 AM
HavokB18's Avatar
Default Re: (94_HATCH)
okay there big guy. i was only stating what i saw k thx. I learned my one thing about honda ecus today.
Old Jul 7, 2005 | 12:07 PM
lak8's Avatar
thanks for you help guys, Im sending the ecu in and they said they would replace it with the orignal H22a 5spd ecu.
tkhang
Mar 11, 2010 06:08 AM
218luder
Jan 2, 2007 05:50 PM
lak8
Jul 4, 2005 11:08 AM
snake679
May 15, 2003 04:27 AM
