GSR throttle cable in eg(b18c)
How would you properly adjust the throttle cable in this 95 ex b18c swap.
car pulls fine till 3-4k rpm where i feel slight difference in acceleration sometimes.
In a GSR, the cable is bracketed against the firewall before it returns to the throttle body, could this be what it is? I have the cable bolt turned all the way to the closest it can to the fixation nut.
Re: GSR throttle cable in eg(b18c) (HondAcura)
You can get the GSR bracket for the throttle cable and it will bolt on the firewall making it just like a stock GSR (throttle cable wise that is).
import-tooner
01-25-2011 05:30 AM
