weird idle problem.
Old Jul 7, 2005 | 09:50 PM
tech0937's Avatar
Default STRANGE IDLE PROBLEM, HELP
just recently got JDM type r motor swapped into my 94 integra. Car runs nice but has a strange idle problem. At a stand still the car idles fine. But once i get moving the car runs good until i let off the gas, the car starts to rev and then it stays idle at 3000 rpm. it doesn't get back to normal until i come to a complete stop. Once i start moving again the same cycle starts over again. Does anyone know why its doing this? At a stand still the car idles perfect. Any help would be appreciated.
Modified by tech0937 at 7:03 AM 7/8/2005
Old Jul 9, 2005 | 03:12 PM
94rs-turbo's Avatar
Default Re: STRANGE IDLE PROBLEM, HELP (tech0937)
all i can say is check all your connections and vacume lines do you have a check engine light on?
Old Dec 20, 2005 | 01:03 PM
Pompiuses's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tech0937 &raquo;</TD></TR><TR><TD CLASS="quote">just recently got JDM type r motor swapped into my 94 integra. Car runs nice but has a strange idle problem. At a stand still the car idles fine. But once i get moving the car runs good until i let off the gas, the car starts to rev and then it stays idle at 3000 rpm. it doesn't get back to normal until i come to a complete stop. Once i start moving again the same cycle starts over again. Does anyone know why its doing this? At a stand still the car idles perfect. Any help would be appreciated.
Did you find out what the problem was? I've got a similar problem....
Old Dec 20, 2005 | 05:52 PM
TypRice's Avatar
check to see if the throttle cable is sticking open?
barrow a idle air control valve from someone and try that(simple)
Old Dec 25, 2005 | 03:29 PM
akteamster's Avatar
Default Re: (TypRice)
same EXACT problem here.
no cel.
started after i put in a new TPS.
did u try cleaning the IACV?
im not sure of the proper way to do so, but if someone else knows....please post.
Old Dec 28, 2005 | 04:31 PM
foam's Avatar
Default Re: (akteamster)
I had a revving problem but I replaced my TPS today. After that it doesn't rev anymore but is sitting at 2.5k on the rev. So I think it might be the same problem as you guys? I am gonna clean the IACV tomorrow.
Old Dec 28, 2005 | 08:25 PM
RTI's Avatar
RTI
Default Re: (foam)
Make sure there is slack in the throttle cable when the throttle valve is closed. You can get away with more slack than you would think.
Old Dec 28, 2005 | 09:20 PM
Opie's Avatar
Old Dec 28, 2005 | 09:38 PM
96jdmitr's Avatar
Posible fixi
have a 96 jdm(rhd) ITR and i had the same prob
to fix this all u need is a volt meter and a philips screwdriver and a friend to help .
step 1. attach volt meter to TPS sensor have some one start the car.
step 2. volt meter should read .4 or 4. volts depending what volt meter u are using.
step 3. if TPS is not reading 4 volts then with screwdriver loosin screws just enough to move TPS around back and forth or up or down until volt meter reads 4 volts
step 4.after u get a 4 volt reading tighten screws and disconnect volt meter and that should fix prob.
I had spent many hours tring to find out why i had that prob I even put on a new idle air contol and that diddn't work but when i check the TPS volts it was reading 2.8-3.2 volt then i mad the adjustments to get 4 volts and it idled like new.So i hope this info helps fix the prob
Kirk@SyndromeAuto
Jan 31, 2007 08:45 PM
ExAcc
Sep 20, 2005 10:49 AM
Lmgrcivic
Apr 11, 2005 11:13 PM
Black 2K
Jul 23, 2003 11:52 PM
