H23 swap in a '94 accord Ex.....
Have any of you swaped a H23 into a 94 Ex vtec? What obsicles are there and what are some techs i need to know specificlly?
I have swaped a fullly rebuilt H23 into my '94 Accord Ex and so far it hasnt been running quite right. And I do have a vibratation, im guessing its from the flywheel /clutch since I have swaped that from the accord. I am currently using the f22 trans.
Also since i have completed half the job , what do you think the cost would come out to get someone to get it running right? I'm already getting sick of the wiring.
Any help is appretiated.
GDD Member
Aside from vibration, what problems are you having? What's not running right?
H23 into an accord is pretty straightforward, everything bolts in with slight narrowing of the driver's side H23 mount to fit. Wiring is similar, just leave the VTEC solenoid/PS disconnected, then you're set. Should be no problem.
