Car will not run, Cel 20 and 41?? Help me pls
Have swaped a B18C(obd2a) into my Civic that is/was OBD0.
the Cel shows: 2 long blinks pauses 2 seconds, den 4long followed by a short one.
I get the car to ignite, rev meter shows about 700rpm, but dies right after. i can run it on the starter and it wil trie to start over and over again. Will the 2 cel codes make that the car will not run? Or should it just be in limp mode?
BTW Is the Cel for obd1 the same as on obd2a(jdm)
I have a honda civic 1995 Lsi(Europe DPFI OBD0)
Erro 20:
Electric load ??????
What is it and were can i find it???
Error 41: ithink
Followed the instructions from Boomslang.us, but the o2 was not collor coded, so i tried it out my self.
Yellow -> yellow/black
White -> white
Orange -> Green/black
Gray-> black
can figure it out.
Thanx for any reply
Erro 20:
Error 41: ithink
White -> white
Gray-> black
can figure it out.
Thanx for any reply
Re: Car will not run, Cel 20 and 41?? Help me pls (khmoe)
Those two codes are not the reason your car wont run. The ELD code(20) means that something is draining your battery. I had that problem before and Ended up being the electrical load detector in the engine fuse box, but my car still ran with it being bad. Try using a new or more powerful battery. As for the o2 code, your car will run, but it will run a little rich if the ecu cant read the o2.
sumoneEK
11-22-2010 11:29 AM
