itr 5 lug conversion brake question???????
Old 07-07-2005, 08:01 AM
dabomb's Avatar
Default itr 5 lug conversion brake question???????
hey guys been searching for a couple of hours and cant find what i need. i have a 92 si hb (4 wheel disc) and i'm doing the 5 lug conv. Will the car brake ok if i just swap the brakes over and don't change the brake booster, master cylinder, proportioning valve
thanks
Old 07-07-2005, 11:24 AM
MrMike's Avatar
Default Re: itr 5 lug conversion brake question??????? (dabomb)
pedal feel will be mushy and/or the brakes will lock up very fast. u'll need to change the master cylinder. I used a del sol vtec non ABS master.
Old 07-07-2005, 02:03 PM
chameleon's Avatar
Default Re: itr 5 lug conversion brake question??????? (MrMike)
man this question is asked every month. please search!!
Old 07-07-2005, 05:49 PM
dabomb's Avatar
Default Re: itr 5 lug conversion brake question??????? (chameleon)
as i stated earlier i did try to search, i searched under 5 lug conversion and under proportioning valve/master cylinder, what should i search under
Old 07-11-2005, 10:05 PM
dabomb's Avatar
was the master cylinder all you changed??? how about the bb or the prop. valve?? did the del sol mc bolt right up to the lines in your eg???
Old 07-11-2005, 10:34 PM
BlueIntegraBoy's Avatar
I would suggest you upgrading to a 90-93 Integra Brake Booster + 1" Master Cylinder to have the same brake feel as an ITR. ITRs have a 1" MC. The DA BB + MC will bolt up fine with the hard lines. Also, get a DA or 94-95 RS 4040 Prop valve. You should be good after that. Oh maybe upgrade to stainless brake lines.
Old 07-12-2005, 06:33 PM
si_lee's Avatar
https://honda-tech.com/zerothread?id=152884
Bucc-i
Suspension & Brakes
04-05-2010 03:15 PM
ejcivicdee
Suspension & Brakes
04-11-2007 07:56 PM
LoNgHoRn
03-11-2007 11:07 AM
jdmB18CT-R
10
08-14-2006 11:42 AM
MyEG6
Suspension & Brakes
33
11-21-2005 07:29 AM
Quick Reply: itr 5 lug conversion brake question???????
