ls crank in b16a block
Re: ls crank in b16a block (slammed00si)
Ive read somewhere that you would have to plug your oil squirters. I think there is a guy named tech43 who knows all about the build up and sells the parts necessary to perform it.
Re: ls crank in b16a block (Falkien)
Tech43 makes a kit that uses the LS crank and rods, bu uses a custom-designed piston with the wrist-pin location moved up.
I believe they have oil-burning issues though.
SkRiBLaH
11-20-2005 09:35 PM
