H22 Swap to Ek. HCP. Accord Rear Bracket ?
Old 06-29-2005, 02:00 PM
Dr. D-Series's Avatar
Default H22 Swap to Ek. HCP. Accord Rear Bracket ?
Im helping a friend swap a H22a into his 97 civic coupe.
He is using HCP mounts.
Can I use an accord f22 rear trans bracket for the swap ?
Is it the same as the preludes h22 bracket ?
I searched plenty.
H22 bracket.
F22 bracket.
h22 f22
Tons of info, just none of what I need.
Some hints.
But nothing that was for SURE.
Thanks for the help.
Old 06-29-2005, 02:50 PM
Sam1am26's Avatar
Default Re: H22 Swap to Ek. HCP. Accord Rear Bracket ? (Dr. D-Series)
Yes you can...
Old 06-29-2005, 03:26 PM
I appreciate the fast response.
Thank you.
Old 06-30-2005, 06:54 AM
lak8's Avatar
i cant remember were and i just spent about 10mins trying to find it but i remember were... someone said and measured both and the f22 and the h22 rear bracket are a little bit different which is why people were having problems with alignment.
maybe someone else knows for sure? if so please let this guy know
Old 06-30-2005, 09:26 AM
Adam.'s Avatar
Default Re: (lak8)
Buy my axles! They are perfect for your swap. Look in my sig!
Old 06-30-2005, 10:34 AM
Thanks for the replies.
My pal has already bought axles but thanks.
Old 06-30-2005, 07:16 PM
RTFM
v4lu3s's Avatar
i have seen newman post that hte h22 bracket is the oen that htey designed the moutns around, and tha tif you dont use it they dont guarantee it will work right. i do also know the brackets are somewhat diff as well
Old 07-08-2005, 06:53 PM
Accord rear bracket did not line up with rear mount.
about 1 1/2 to 2 inches too high.
Just a heads up for some people.
Old 07-08-2005, 10:59 PM
HavokB18's Avatar
Odd that bracket didnt line up at all wiht my swap... Guess its becasue its an EG eh...
Old 07-09-2005, 04:36 AM
It bolted right up to the trans.
Old 02-17-2013, 06:48 PM
Rice a Ronii's Avatar
Does anyone know if the f22 bracket will fit a 00 hatch w/ h22 swap?
Old 02-18-2013, 01:53 PM
ESP.net's Avatar
This is old thread but will help you out...
90-97 Accord Dx and Lx 5 spd and all 92-01 Prelude Auto or 5 spd. Use the same Rear T Bracket which uses the short 3 bolt rear mount not tall 4 bolt. This should be the Rear T Bracket all Hybrid swaps use.
Old 02-25-2013, 07:10 AM
Ok thx I appreciate it
Tuner Eddy
05-28-2014 10:02 AM
1QwIkEf
01-25-2012 06:47 AM
accordmatt
01-03-2011 08:53 AM
UnknownDC2
04-30-2008 11:27 AM
fabe85
06-23-2007 06:18 AM
Quick Reply: H22 Swap to Ek. HCP. Accord Rear Bracket ?
