Quik H22 in EK Questions...
I did search...
I am trying to find out What alternator belt I need to use in my EK with my F20B (H22a).
I also need to know what Upper radiator hose to use. Thanks
Re: Quik H22 in EK Questions... (Sille98)
For my alternator belt, I took a string and measured it around the pulley's, then counted the ribs in the pulley's, then I took it to a auto store and they sized one up for me. And for the radiator hose, I used one from a integra.
Re: Quik H22 in EK Questions... (Sixgundone)
So one from a GSR would probably work since it is DOHC. Well so is the LS. I will try the GSR Radiator pipe I suppose...
Thanks for the reply...
Any other opinions are welcomed as I will be ordering these Monday morning...
I think they are the same. Also, just go to your local auto store and buy a teg upper radiator hose. If it doesn't fit, then eye it up and measure the outlets on the radiator, and the block.
That should do you just fine
You don't really need to go and order the hoses unless you want a specific color or something.
hondastreet
03-17-2004 09:32 AM
jeremy.
03-01-2004 12:47 PM
