Few quick h22 eg q's
I know for a fact that these have all been beaten to death.. But I can't find them anywhere
Thanks for help, if you help. No flaming. Thanks.
1. What's a good clutch/flywheel/pressure plate combination for an h22?
2. I know there's a company that makes a custom testpipe for the h22 header to meet the civic EG exhaust... don't know what it is though.
I know I have more questions... I'll ask them as I remember them
Thanks!
Thanks!
Re: Few quick h22 eg q's (93preludeh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93preludeh22 »</TD></TR><TR><TD CLASS="quote">1. What's a good clutch/flywheel/pressure plate combination for an h22?</TD></TR></TABLE>
I tell people to get a replacement exedy clutch to keep the costs down. I have seen them hold 165 wtq with no problems. If you plan on turboing it or a big na build (higher RPMs), you should look into a better clutch.
Sidenote: Rotieatter (thats his SN on here) gets good deals on clutches and other parts you may need. He will help you out with good prices.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93preludeh22 »</TD></TR><TR><TD CLASS="quote">2. I know there's a company that makes a custom testpipe for the h22 header to meet the civic EG exhaust... don't know what it is though.</TD></TR></TABLE>
You talking the stock h22a header? Because it is longer (alot) then b/d-series. You will have to cut the exhaust rither way. I have never seen what you are talking about.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93preludeh22 »</TD></TR><TR><TD CLASS="quote">3. What's a nice suspension setup for the EG? What kind of full coilovers?</TD></TR></TABLE>
Konis and ground control. One of the better systems out there. You can get the whole set-up for about 750.
Search the road race forum for info on spring rates
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93preludeh22 »</TD></TR><TR><TD CLASS="quote">4. What is an effective traction bar for the EG?</TD></TR></TABLE>
What mounts you running?
Re: (93preludeh22)
hasport mounts
Exedy clutch seems to be doing well with my h22R
i have Jun Flywheel but, i have ran and would have ran a Clutchmaster flywheel if i were not to have gotten that flywheel in my deal. As i have had about 4 of them now in various cars and they were great.
Lcon traction bar is what i will be going with soon.
I run a NEX full coilover have ran them in about 4 differen EGs now with different swaps and like them alot better than any spring/strut combo i've had or ridden in.
I am also planning on buying the megan racing H brace seems like 50 dollars well spent
http://www.meganracing.com/upl...2.jpg
Re: (Sixgundone)
if you think about it. Even if it is cheap... It will still tie the front of the car together well in combination with a Tractionbar LCAs with new bushings good UCAs and that Hbrace seems like it would make for a pretty nice setup up front..
Re: (HavokB18)
1. For your clutch, I'd go with an ACT extreme pressure plate, ACT hybrid street disc, and ACT ProLite flywheel. It's a great combination and it doesn't cost that much. Mine is holding great!
2. Get your test-pipe from http://www.kteller.com. I got a 2.5" stainless from Mike (at KTeller), and it's great!
Re: (93preludeh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93preludeh22 »</TD></TR><TR><TD CLASS="quote">does the kteller test pipe mate the h22 manifold/header to civic exhaust?</TD></TR></TABLE>
I would like to know this also.
last civic h22 swap i did i put the oem h22 header on, and had to remove the civic cat, and at that point the header was abotu 2 inches from the exhaust system.
usually what i do is cut and weld in a cat and flage to bolt to teh header.
Re: (93preludeh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93preludeh22 »</TD></TR><TR><TD CLASS="quote">how streetable is the 6puck? I'll be driving this to work every once in a while.... </TD></TR></TABLE>
well, everyonnce in a while is ok, its not that bad really. i mean, i drive mine just about every day, and its easier if ur car is hydraulic instead of cable... but overall, i think its very streetable.
