EG suspension on a 00 si
Ok.. I have searched and found a few things but not a straight forward answer.
I have a delsol and I have spent tons of loot upgrading the suspension. Is there anyway to use it on the SI...
Re: EG suspension on a 00 si (RotiEatter)
well my main concern is just the coilovers.. But I have upper and lower control arms front rear sus tech sways. I am pretty sure the contorol arms wont work but I think maybe the rear sway will work and the coilovers but not sure
Re: EG suspension on a 00 si (justinwipf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by justinwipf »</TD></TR><TR><TD CLASS="quote">well my main concern is just the coilovers.. But I have upper and lower control arms front rear sus tech sways. I am pretty sure the contorol arms wont work but I think maybe the rear sway will work and the coilovers but not sure</TD></TR></TABLE>
I thought the only real differences were the LCA's. The coilovers will work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by justinwipf »</TD></TR><TR><TD CLASS="quote">I know I cant use the LCA's But the rear strut mounts I think are bigger on the eg</TD></TR></TABLE>
They are, the bottoms of the strut forks are slightly wider in the rear on the EG as opposed to the EK's. You can fill the space with washers on either side of the control arms on the EK and use the EG suspension. The difference is very minimal, about 1/8" gap on each side of the arm when you put the EG struts/coilovers on.
KStuned
09-22-2002 09:44 PM
