How to fix the ICV?
Old Jul 3, 2005 | 07:36 PM
DA9teg93's Avatar
Default How to fix the ICV?
my idle is bouncing all the time and i want to know how to fix the idle control valve (icv). please help asap! need to pass smog REAL soon!!
Old Jul 5, 2005 | 01:55 AM
UNKNOWN_MEMBER's Avatar
it's iac (idle air control). not icv. you try searching? take the 2 bolts behind of it out. Take the coolant lines off of it. Spray brake/carb cleaner in the two holes that mounts onto the IM. Let it set. Blow it off with a air compressor then do it agian to make sure. Blow it off with air compressor. Make sure everything is dry and put it back on. Don't forget to put the rubber gasket. You throwing code 14?
95gsr@530
May 13, 2019 10:43 AM
jojo69
Oct 29, 2006 05:35 PM
b16acrxer
Aug 31, 2004 09:02 AM
pacifico
Mar 30, 2004 06:26 PM
