b18c head on a b16 block
Old Jul 19, 2005 | 06:20 PM
MR. BAR's Avatar
Default b18c head on a b16 block
I did a lot of searching on this but found very little info other than stuff on the opposite, poor man type-r's. I found a good deal on an bare 84mm GE sleeved b16 block and i was wondering what kind of complications or adjustments will need to be made in order to put my gsr head on this block? The block comes bear so will it be possible to transfer assemby parts, head gasket, water pump, oil pump, timing belt, oil pan, wires sensors from my blown gsr block onto the b16 block? Also from which block will i need to order ARP head studs because i already have them in my GSR block and i want to know if i can transfer them (i searched this but only found info on other head/block mixes)? What kinds of parts will i need to order in order to make this work?
I hope to make this a solid turbo car so thanks for the help!!! and ill keep you guys updated.
Old Jul 20, 2005 | 09:58 AM
MR. BAR's Avatar
bump
hatchet_honda
May 8, 2009 04:11 AM
FadedDC2
Jun 13, 2007 02:16 PM
xDicktonesx
Aug 6, 2005 09:04 AM
MR. BAR
Jul 25, 2005 07:33 AM
