WHAT'S THE DIFFERENCE BETWEEN B20B AND B20Z LONGBLOCKS.
I want to purchase a b20z longblock and am going turbo with it on the stock block.im in so.cal and im having trouble finding a b20z longblock all i come across are b20b longblock's.can someone tell me whats the difference between the two and where i can find a b20z longblock in so.cal la area for not like a $1000.
Re: WHAT'S THE DIFFERENCE BETWEEN B20B AND B20Z LONGBLOCKS. (K SERIES)
B20B has 8.8:1 compression - this is the block you want for turbo
B20Z has 9.6:1 compression and a taller intake manifold stack for increased midrange torque
Re: WHAT'S THE DIFFERENCE BETWEEN B20B AND B20Z LONGBLOCKS. (93b16CivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93b16CivicSi »</TD></TR><TR><TD CLASS="quote">B20B has 8.8:1 compression - this is the block you want for turbo
B20Z has 9.6:1 compression and a taller intake manifold stack for increased midrange torque</TD></TR></TABLE> and also wont clear a civics hood
most of the power difference on the b20b and b20z is from the intake manifold. So if you were to slap on a b20z manifold to a b20b, it should perform fairly close to a stock b20z, obviously not as well due to the lower compression.
The DX Rex
12-12-2004 03:14 PM
b20, b20b, b20z, buy, compression, diff, differance, difference, differents, diffrence, honda, longblock, longblocks, place, whats
