OBDII H22 in EK...ecu questions
i have a p72 teg obd1 jun ecu in my h22 civic. i need a stock ecu becuase nysi needs to read the obd2 plug to pass inspection...and thus i cannot. does anyone know what ecu would work to pass emissions?? i understand that the p5m prelude ecu has an immobilizer so thats proly out of the question. im gettin a p28 obdII ecu. im gonna try that. does anyone know if this will work? another thing is i have VAFC which is spliced into the stock harness at the connectors to the ecu...will this affect the inspection or throw a code?
Re: OBDII H22 in EK...ecu questions (oni3)
lol...throw away vafc...yeah i bought the car with it installed in the dash, so i dont really want to take it out, plus i like the dig. rpm readout like i said b4, the p5m ecu has immobilizer and i dont know how to get it to work. if someone knows how to remove the immobilizer without getting a cel info would be appreciated(allready searched but know detailed instructions on how to do it)
Re: OBDII H22 in EK...ecu questions (Sixgundone)
If the vafc effects it, just cut it at the harness and solder it back when its all done.
I dono if it does effect it but wait till you get a second opinion.
Also, Try finding out if the immobilizer is disabled or removed, if it would effect your inspection or not. Hope I helped
RPM JDM
11-13-2009 04:17 PM
