k-series cam gears on b?
Re: k-series cam gears on b? (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked »</TD></TR><TR><TD CLASS="quote">NO
Chain VS Belt</TD></TR></TABLE> lucky them..
EDITn that note, where the hell is the fab work for a b-series timing chain kit eh?
Modified by Hapexamendios at 5:18 PM 7/13/2005
Modified by Hapexamendios at 6:05 PM 7/13/2005
Re: k-series cam gears on b? (K_Motor)
lol i cant believe I missed the obvious. Does anyone know the outter diameter of the k-series gear? May be able to grind off the teeth
GDD Member
Re: k-series cam gears on b? (UberTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UberTeg »</TD></TR><TR><TD CLASS="quote">lol i cant believe I missed the obvious. Does anyone know the outter diameter of the k-series gear? May be able to grind off the teeth</TD></TR></TABLE>
It's not going to work, end of thread.
Go find a custom motorcycle shop, look at the gearing of belt/chain driven bikes. Totally different.
Re: k-series cam gears on b? (slomofo)
no i meant grind off the teeth, then slip the adjustable part off of an aftermark gear and weld it in place. The adjsutable cam gears give a large advantage and i want them in my b does anyone have any pix or technical information on the gear mechanism?
Here is pix and tech info on the VTC gear mech http://www.hondata.com/tuning_the_tsx.html. Its a tsx but all of them works the same way.
what the hell is the point of this thread!??! buy some B series adjustable gears for $100 on ebay and be done with it. there is no gain or benefit from whatever your trying to do.
Re: k-series cam gears on b? (chameleon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chameleon »</TD></TR><TR><TD CLASS="quote">what the hell is the point of this thread!??! buy some B series adjustable gears for $100 on ebay and be done with it. there is no gain or benefit from whatever your trying to do.</TD></TR></TABLE>
yah those ebay adjustable cam gears offer no advantage over the k-series gears...
Modified by UberTeg at 6:47 PM 7/15/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UberTeg »</TD></TR><TR><TD CLASS="quote">yah those ebay adjustable cam gears offer no advantage over the k-series gears...
Modified by UberTeg at 6:47 PM 7/15/2005</TD></TR></TABLE>
BlackHXCoupe
20
07-20-2006 12:16 PM
