need info on swap engine!!
Old Jul 11, 2005 | 02:15 PM
honda_turbo's Avatar
Default Hello, i'm in internal conflict, please halp me!!!
hello
i have a civic 99' 1.4 90hp (d14z2)
i want, no, i mast to make her stronger and faster.
so i have some idea and i want you to help me make a disition, please.
1. poot turbo t3\t4 on tath engine
2. swap to a zc engin 1.6 130hp - i think i dont need to swap the tren and the AXLES
3. go on the big - b16 engine that min thet i need to swap tren and all kinde of things (expensef)
i want to go on option 2 what do you say??
ps
that my car:
thank's
arik
Modified by honda_turbo at 3:27 PM 7/11/2005
Modified by honda_turbo at 1:42 PM 7/25/2005
Old Jul 11, 2005 | 02:23 PM
robotosan's Avatar
Default Re: need info on swap engine!! (honda_turbo)
you should just get the complete d16y8 swap. you will need to wire for vtec
Old Jul 11, 2005 | 02:30 PM
Default Re: need info on swap engine!! (CRXhf_89)
yes i now about the problem with the wiring to vtec engine, and i need alsow computer for that engine
but do you think that d16y8 is beter then the zc engine??
thank you
arik
Old Jul 11, 2005 | 03:01 PM
robotosan's Avatar
yes since the zc is obd-0 and yes theres the rare obd-1, there will be more to wire with the zc then the y8
Old Jul 11, 2005 | 03:29 PM
hondaZvic's Avatar
if you really want to make it stronger and faster go with option 3. b16.
Old Jul 11, 2005 | 04:39 PM
VTECVillain's Avatar
I'm not sure what all engines were available in Israel, but as mentioned the D16Y8 1.6L SOHC VTEC or your equivalent of would be best. This will keep you from having to change the tranny, axles, etc. that is required with a B series swap. Do the SOHC VTEC swap and piece together a turbo setup and I'm sure you'll be pleased.
Old Jul 12, 2005 | 06:24 PM
bboylito's Avatar
Default Re: need info on swap engine!! (VTECVillain)
will you be doing the work yourself????
if so then you should understand just how hard it is to do this alone for the first time
if you are paying someone to do it then do it right the first time do not pay someone to put in a zc or d16 engine that is a waste of money and labor, just get the b16 but even still i would suggest a gsr b18c1
what i am trying to say is either do it right the first time and get something you will be very happy with and know the investment brought you joy then to spend a little bit less of money and just be kind of happy and not fully excited about your car
i am in the middle of my swap and i'm miserable because i realize that i should have just saved for a little bit longer and got the better engine
Old Jul 18, 2005 | 02:22 PM
Default Re: need info on swap engine!! (bboylito)
first i want to tell you all thank you for your respand, thanx.
now i want to swap to the d16y8 and piece together a turbo kit.
but now i have an idea and i hoop you like it
it is just a try to make it - i want to put a turbo kit on my d14 wath do you say??
it's just an idea to tets this eng maby it will drive nice just for now and if it wont work i'll go on the d16
i dont want to go on the b18 becuse it will make me have to swap ernest+ tren+exles and alut of uther stuf = more many !!!
thnak you and good neight
arik
Old Jul 19, 2005 | 06:18 AM
kingpin45's Avatar
I just pulled out my d series 1.6 95 SOHC vtec engine ran great when i took it out never had any problems with it i am just upgrading to H22 let me know if your interested i'll let it go cheap.
Old Jul 19, 2005 | 05:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_turbo &raquo;</TD></TR><TR><TD CLASS="quote">i want to put a turbo kit on my d14 wath do you say??</TD></TR></TABLE>
I'd say go for it because you don't really have anything to lose. If you tune it (even just a street tune with a wideband) with a program such as Uberdata, Hondata, etc. you should be safe as long as you don't go too high with the boost. Later on you'll be able to transfer the turbo kit over to the SOHC VTEC motor if you so choose to do the swap. You could also swap it over to a B series by changing the manifold and some minor downpipe and charge pipe mods.
Old Jul 25, 2005 | 11:58 AM
hello
ok i decide to go on the turbo kit to my car
for now i have:
1. manifold from grady
2. turbo t3
and now i understand that i need those parts:
1. Apexi SAFC Super Air Flow Converter
wich i find in EBAY he
2. 450 cc injectors
3. intercoler i dont have a link but i think to put intercoler of dukato
4. "down pipe" i dont have
5. i need this parts as well to to supply the oil to the turbo
now i have som questions :
1. do you have this parts that i need include the turbo ana the manifold maby from here it cost cheaper then in israel.
2. if you have any thing that can halp me build that project i will be most thank you all.
arik
Modified by honda_turbo at 1:19 PM 7/25/2005
Old Jul 25, 2005 | 12:22 PM
RACEPAK's Avatar
i say turbo the d14 the ghettoest way there is, and than after it will blow swap it.
EDIT: or sell it.
Old Jul 25, 2005 | 05:26 PM
SiRTifiedacc's Avatar
Default Re: need info on swap engine!! (RACEPAK)
lol.. he said poot.. sorry guys.. i'd say LS..B18B then later go out for vtec head.. cheap and a progressive swap.. and alotta power in the end
Old Aug 9, 2005 | 04:55 AM
Default Re: need info on swap engine!! (SiRTifiedacc)
ok today i order b16 eng and i hoop that next week it will finish
now i'd like to now wich b16 you recomended for me ?
and he said that i need adaptor for obd1 , do i???
wich compter feet to that eng??
thanl you all
arik
Old Aug 12, 2005 | 07:36 AM
Earthworm Jim's Avatar
Default Re: Hello, i'm in internal conflict, please halp me!!! (honda_turbo)
Sunroof, is that custom?
Old Aug 12, 2005 | 08:10 AM
veggiemaster's Avatar
Default Re: Hello, i'm in internal conflict, please halp me!!! (TheGeneral)
that turbo wont spool at all on a d14. your best bet is to swap it.
Old Aug 12, 2005 | 09:45 AM
RACEPAK's Avatar
Default Re: Hello, i'm in internal conflict, please halp me!!! (veggiemaster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veggiemaster &raquo;</TD></TR><TR><TD CLASS="quote">that turbo wont spool at all on a d14. your best bet is to swap it.</TD></TR></TABLE>
WTF r u talking about i have a t3 in my car and it hit full boost at 4000rpm.
Old Aug 12, 2005 | 12:50 PM
Get a D15 for like $600 and slap a turbo on it
Old Sep 6, 2005 | 11:42 AM
Default Re: Hello, i'm in internal conflict, please halp me!!! (The_General)
good neight friends
i have anuther dilema
i'm going to spen close to 5,000-6,000 $ so i want to make a good call
now i have onli 2 option:
1. swap my motor to a zc eng and in 1 year a turbo kit
2. replace my car to honda Prelude vti (i like that most)
wath do say abuat it
arik
jjohn6438
Honda Civic (2001 - 2005)
Nov 13, 2006 11:51 AM
CRXCIVICMIX
Sep 29, 2005 06:49 PM
sol-man
Jan 22, 2002 12:02 PM
