help on intake swap!
Old Jul 7, 2005 | 10:11 PM
civicdude16's Avatar
Default help on intake swap!
I need to beef up my car somehow.
I have a D15b2 w/ the shitty carburator intake. What do i need to do if I get the mtfi intake? What parts do I need to get it to work?
Old Jul 8, 2005 | 05:18 AM
VTECVillain's Avatar
Default Re: help on intake swap! (civicdude16)
You will have to do a complete MPFI swap - MPFI D series manifold, 4 OBD0 fuel injectors with clips and resistor box, 88-91 Civic/CRX Si or CRX HF distributor, and also a PM6 or PG7 ECU. Then you will have to do the wiring mods to your DPFI harness. I know it sounds like a lot but really it isn't. It will be the single best mod you can do to liven up that motor.
Old Jul 8, 2005 | 06:01 AM
Ministry's Avatar
lose the motor...
/had to do it
Old Jul 9, 2005 | 07:32 PM
Default Re: help on intake swap! (VTECVillain)
thanks for the info. Ill just have to find a wrecked crx some where.
Old Jul 9, 2005 | 07:34 PM
Default Re: help on intake swap! (dreamer)
Man it will be awhile for I swap the motor. When I swap the motor ill probably put in a b16a or B18.
Old Jul 9, 2005 | 07:59 PM
What kind of wiring mods will I have to do to the harness?
Old Jul 10, 2005 | 05:19 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdude16 &raquo;</TD></TR><TR><TD CLASS="quote">What kind of wiring mods will I have to do to the harness?</TD></TR></TABLE>
You have to do a DPFI to MPFI conversion. Do a search and you should find all the details as it is discussed a lot.
fcrizzo
Oct 11, 2009 05:22 AM
dohc_profile
May 31, 2007 11:33 AM
i70racer69
Dec 5, 2006 04:35 PM
Civiclized
Nov 17, 2004 03:15 PM
