idle problem
I have a 96 honda accord with a 94 h22 and my car idle between 1500- 3000rpm s up and down no matter if cold or warm. I disconnected the iacv and the idle went down 1200-1500rpm stills goes up and down between these rpms, So what could be the problem.
Possible vacuum leak IMO, the IACV is working and trying to control idle, but it is out of its range. I had a similar problem with a h22 swap and a leaking air bypass valve on the manifold. Prelude ECU or what engine management are you using?
immalooser
Feb 18, 2009 05:23 AM
