high compression ls/vtec question
I recently built a high compression 12:5:1 compression ls/vtec. I was told by someone that I will have to detune the timing if I am going to run 93 octane gas, or use as a daily driver, and would loose a good bit of power. Is there anyone that has done a high compression motor like this that has had any problems? Or is there someone that built one and had a succesful daily driver from the build? All in all I am just asking what problems should I expect from a build like this for a daily driver?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baby type r »</TD></TR><TR><TD CLASS="quote">I recently built a high compression 12:5:1 compression ls/vtec. I was told by someone that I will have to detune the timing if I am going to run 93 octane gas, or use as a daily driver, and would loose a good bit of power. Is there anyone that has done a high compression motor like this that has had any problems? Or is there someone that built one and had a succesful daily driver from the build? All in all I am just asking what problems should I expect from a build like this for a daily driver?</TD></TR></TABLE>
i am runnin the same setup and made decent power on the dyno...the only thing holdin me back is the fact i am still runnin stock b16 cams and came gears and the bottom end just has ARP rod bolts and CTR pistons and punched .25mm over to accommidate the pistions.....also mine IS a daily driver and moves pretty good on the street...and yes you will have to retard the timing to prevent detonation
Heres my setup:
B18A1 Block
CTR(Civic Type R) pistons
Milled B16 Head (42 cc combustion chamber)
Blox Intake manifold
Skunk2 68mm Throttle Body
Hondata Heatshield Intake Gasket
Cold Air Intake
DC Sports JDM 4-1 Ceramic Header with 2.5 inch collector
2.5 inch Magnaflow Hi flow cat
GReddy EVOII cat back exhaust
P28 ECU with HONDATA S200
Hurst short throw shifter with Skunk2 weighted shift ****
95 Integra LS tranny with Competition Clutch Stage 2 Street Clutch
95 Integra GSR tranny(waiting for $$$ for a LSD)
Heres my setup:
B18A1 Block
Cold Air Intake
thanks for the info. I am still trying to get mine running right now and am running into problem after problem. I just got a new set of spark plugs because the other ones were hitting my pistons and now i can't get any fire from the new ones. I am getting the MSD ignition and distributor cap soon. Other than that this is my set up and if anyone can point me in the right direction to get it tuned when I get to Ft Belvoir I would greatly appreciate the help.
My Set up:
b18b block 81.5mm
weisco 12:5:1 pistons
SRP forged rods
SRP forged, knife edged 95mm crank
Moroso oil pan
b16 head ported polished
JUN Dual valve springs
SiR II cams
ported intake manifold
70mm throttle body
4 to 1 jdm header 2.5" collector
Megan exhaust
Skunk 2 test pipe
J's Racing Carbon intake
310cc Rc injectors
Mishumoto radiator
Mtuber reprogramed ecu
My Set up:
b18b block 81.5mm
SRP forged rods
Moroso oil pan
SiR II cams
70mm throttle body
Megan exhaust
Skunk 2 test pipe
310cc Rc injectors
Mishumoto radiator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junciviceg »</TD></TR><TR><TD CLASS="quote">you should not have to retard timing.Its all about spending the money and actually getting it tuned.</TD></TR></TABLE>
Exactly. Get that thing tuned. With that kind of compression its gonna be near impossible getting it running right. If you get it tuned you can keep a descent amount of timing and still run it on pump gas.
Also, whats up with the stock b16 cams? Those cams will do nothing but hold back power with that kind of compression and displacement.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baby type r »</TD></TR><TR><TD CLASS="quote">yeah the cams are next on my list, I am going to run the skunk2 pro1 cams and cam gears. any suggestions on where to get the car tuned in the DC area?</TD></TR></TABLE>
Inline Pro in Springfield Va.
Inline Pro does a good job....if you make any power though expect your car to get stolen. You could also check into Brauning Motorsports in Maryland. Those are the two I know of in the area.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Creator »</TD></TR><TR><TD CLASS="quote">Inline Pro does a good job....if you make any power though expect your car to get stolen. You could also check into Brauning Motorsports in Maryland. Those are the two I know of in the area.</TD></TR></TABLE>
Damn.....didnt think those guys were that crudey.....
hey thanks for the help do you have the numbers for either one of the places so I can get in touch with them when I get there? I have thought of the BC 4's but don't know if I would want to run the skunk2 pro2's.
yea bigger cams or run type r's ive seen good number with type r's just get some aftermarket cam gears.
im building a ls/vtec now
Built ctr head
stage 3 pro series cams
blox cam gears
brian crower springs and retainers
supertech valves
rc 550cc injectors
aem fuel rail
victor x manifold (currently in the market for the new ultra series)
skunk2 70mm tb
stock b18 bore block
supertech block guard
oem head gasket
13:5:1 cp pistons
scat i beam rods
scat knifed crank 89mm
acl race bearing
4 to 1 headers
gsr oil pump
wanna see what ima put down on dyno should be done soon in a yellow eg hatch
Built ctr head
blox cam gears
supertech valves
rc 550cc injectors
aem fuel rail
skunk2 70mm tb
oem head gasket
13:5:1 cp pistons
scat i beam rods
acl race bearing
4 to 1 headers
gsr oil pump
JonDick
Dec 20, 2010 10:27 PM
Rhymenoceros
15
Apr 15, 2006 03:59 PM
highflyinhonda
Dec 6, 2005 10:33 PM
