Swap Won't Start?
Swap Won't Start?
I have had a JDM H22A in my EK for about five months.
I recently took it out to replace the timing belt/tensioner conversion, clutch, flywheel, and transmission.
I put the motor back in, and it doesnt start.
When I put the timing belt back on I noticed that the intake cam is a little off, but when I notched it another tooth over, or was further then it was before I had notched it over another tooth.
Could having the balancer shaft belt missaligned have anything to do with the motor not turning over? It was previously ran without a balancer shaft belt, and ran fine.
Re: Swap Won't Start? (EKHWhat)
need some more info.
The balancer shafts won't affect starting. IT will just make the thing vibrate like a **** if it's off at all.
Does it turn over and not start, or not turn over at all? Any noise?
[713]
05-14-2012 03:23 PM
slowsinglecam
11
12-24-2011 07:59 AM
