b18c-r swap
b18c-r swap
hey guys i currently have a 97 ex coupe wit a 99 b16a2 motor. Im running the si computer so i got the obd2a to obd2b harness, now i wanna purschace a 98 jdm b18c typer. wat problems would i run into wit this swap. Like for example i heard the jdm type r hub is 36mm and mines is 32mm so wat should i do? use usdm axle? and also the collector in the header is 2.5 inch would that be a problem? thanks for the info guys really appreciate it
