clicky main relay on a 99 ek hel plz
Old 03-03-2007, 01:01 PM
EK FLY's Avatar
Default clicky main relay on a 99 ek hel plz
my main relay is clicking badly after I swap my obd1 gsr motor in my 99 ek cx hatch , i'am using 99 ex coupe auto engine wire harness , most of the ppl tell me to check my grounds , but I check and reecheck and check again all my grounds ( thermostat housing ,valve cover,tranny case ) but still I check all of my fuses , all of them where fine no problem at all with the fuse box , what could be my problem
ps today i test for continuity on relay ground wire and chassis and there is continuity
Old 03-04-2007, 08:47 AM
H-powerd's Avatar
Default Re: clicky main relay on a 99 ek hel plz (super-hatch)
i had the same prob, when ever i would try to the ingnition on it would just click. did u try looking for a bad fuse under the dash and under the hood? that was my problam. hope that helps.
Old 03-04-2007, 09:43 AM
EK FLY's Avatar
Default Re: clicky main relay on a 99 ek hel plz (H-powerd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H-powerd &raquo;</TD></TR><TR><TD CLASS="quote">i had the same prob, when ever i would try to the ingnition on it would just click. did u try looking for a bad fuse under the dash and under the hood? that was my problam. hope that helps.</TD></TR></TABLE>
I will try and replace all fuses and go from there , btw all fuses are good tho
Jaynik
12
08-19-2012 04:23 AM
HondaSunshine
03-18-2012 08:13 AM
D12Beast
16
02-01-2011 04:21 PM
cars
10
08-03-2010 03:30 PM
EK FLY
03-04-2007 05:49 AM
Quick Reply: clicky main relay on a 99 ek hel plz
