GSR oil/water pump identification. Need a little help
Just bought and assembled LS-V. I don't know if the Oil and Water pump are LS or VTEC units. Are there any tell tell signs or numbers on the casings of the pumps that will tell me what motor they are from? Any info is a start. Thanks for checkin me out.
Re: GSR oil/water pump identification. Need a little help (the4g4d)
There are 2 b series water pumps....19t = LS....and a 22t = "vtec". As far as the oil pump goes....I know there is a way to tell the difference but I'm not 100% sure what it is. Also if ur timing belt is an ls "p75" u know atleast ur water pump is an ls. Vtec water pumps require a gsr "p72" timing belt on ls-vtec setups.
Re: GSR oil/water pump identification. Need a little help (JoePSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoePSI »</TD></TR><TR><TD CLASS="quote">Can OBDII oil pumps be installed on OBDI engines without issue?</TD></TR></TABLE>
PM'd
PM'd
Re: GSR oil/water pump identification. Need a little help (idriveacoupe.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveacoupe. »</TD></TR><TR><TD CLASS="quote">
PM'd </TD></TR></TABLE>
Answered all my questioons. Thanks
where would the bolt holes be for the CKF? Thanks for all the help so far guys.
B16Civic93
06-14-2005 07:18 AM
