K-Pro in a K20a3...Limp Mode, Cannot load map.... HELP!
Old Feb 5, 2007 | 07:56 AM
OnePointFive's Avatar
overrated.
Default K-Pro in a K20a3...Limp Mode, Cannot load map.... HELP!
Vehicle: '93 Civic Si
ECU: K20a2 with KPro
Mods: K20a3 with DC Sports Header. Hybrid harness, fuel rail, pressure regulator. Otherwise, motor is stock.
Problem:
I have a K20a3 swapped '93 Civic hatchback. Car runs in limp mode, check engine light is on, will not rev past 4000 rpms. K-Manager is reading the ECU fine, it reads ignition, but whenever i try to load a k20a3 stock map onto the ECU it gives me the error message "Upload Failed!". the LED's on the ECU indicate that the ECU and K-Manager are communicating just fine.
I have consulted a couple local tuners around me and one told me that the k20a2 ECU, even when equipped with Kpro is not compatible with the k20a3, and the other told me it should be just fine since it has Kpro.
Regardless, either way i am stumped.
Thanks in advance for the assistance
Old Feb 11, 2007 | 06:58 AM
junciviceg's Avatar
Default Re: K-Pro in a K20a3...Limp Mode, Cannot load map.... HELP! (OnePointFive)
take it apart and check the board some times the screw backs off and the board seperates
Old Feb 12, 2007 | 06:13 AM
G2AT8K's Avatar
Default Re: K-Pro in a K20a3...Limp Mode, Cannot load map.... HELP! (junciviceg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junciviceg &raquo;</TD></TR><TR><TD CLASS="quote">take it apart and check the board some times the screw backs off and the board seperates</TD></TR></TABLE>
yes it does
Old Feb 12, 2007 | 07:45 PM
locash's Avatar
Clear the security first.
Old Feb 12, 2007 | 07:52 PM
overrated.
Default Re: K-Pro in a K20a3...Limp Mode, Cannot load map.... HELP! (locash)
no security on the ECU.
the fellas at hondata advised that i check the wiring. since the car was wired by someone else, and it resembles wiring a 4yr old would have done, i am going to have the wiring completely redone and see if that does anything.
Old Feb 12, 2007 | 08:31 PM
midwesta's Avatar
mm limp
Old Feb 12, 2007 | 09:21 PM
SiYouLater's Avatar
Make sure you are using the latest version of K-Manager!
Old Feb 12, 2007 | 09:23 PM
overrated.
Default Re: K-Pro in a K20a3...Limp Mode, Cannot load map.... HELP! (SiYouLater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiYouLater &raquo;</TD></TR><TR><TD CLASS="quote">Make sure you are using the latest version of K-Manager!</TD></TR></TABLE>
sure am
b20vteclsintegra
Dec 30, 2011 10:07 PM
msinsky14
Jan 31, 2009 11:59 AM
iakona
Jul 15, 2003 01:14 PM
Stop the Beast
May 27, 2003 01:35 PM
