OBD2 Ecu in OBD1 chassis
I ve seen harness that will allow you to run Obd1 Ecus in a Newer Obd2 Chassis. Is there anyone that know where I can get one that will do it the other way around, I want to see if I can use an Obd2 Ecu in a Obd1 Chassis. Or at least where I can the Connectors, so I can then make a converter. The reason I ask is cause I have a standalone for a 98 Prelude, and I want to put it in my 92 prelude. Thanks to all in advance.
Re: OBD2 Ecu in OBD1 chassis (cparreno)
they have them at http://www.rywire.com for like $125, i couldnt find 1 of the $65 ones on ebay. I am swapping in a '01 gsr into a '94 ls
