k24 question
Old Feb 4, 2007 | 11:52 AM
92eg-pa's Avatar
Default k24 question
Can i turn a crv head into a tsx head by just simply swaping cams and cam gears or do i need to swap all the parts over?
Thanks
Old Feb 4, 2007 | 03:03 PM
v4lu3s's Avatar
RTFM
you would need to add the vtec rocker assembly on the exhaust side as well, from hat i have read that is bolt in as well.
Old Feb 4, 2007 | 05:18 PM
92eg-pa's Avatar
Default Re: (v4lu3s)
thanks
Old Feb 5, 2007 | 07:30 AM
Nikos's Avatar
Default Re: (99Civb20)
NOOOOOOOOOO
you cannot do it..
It;s like converting a LS head into a B16a/b18c1 head.. Not possible.
Old Feb 5, 2007 | 01:41 PM
92eg-pa's Avatar
Default Re: (Nikos)
ok, what else is different between them. any more help
Old Feb 5, 2007 | 03:09 PM
Nikos's Avatar
night and day.
One (tsx) uses vtec style rockers and lost motion springs... and 3 lobe cams.. then other one doesn't..
There is a detailed article from honda tuning you can read about this
http://ivtecdaily.com/rsx/arti...1.jpg
http://ivtecdaily.com/rsx/arti...2.jpg
http://ivtecdaily.com/rsx/arti...3.jpg
http://ivtecdaily.com/rsx/arti...4.jpg
http://ivtecdaily.com/rsx/arti...5.jpg
http://ivtecdaily.com/rsx/arti...6.jpg
http://ivtecdaily.com/rsx/arti...7.jpg
http://ivtecdaily.com/rsx/arti...8.jpg
http://ivtecdaily.com/rsx/arti...9.jpg
http://ivtecdaily.com/rsx/arti...0.jpg
Old Feb 5, 2007 | 03:23 PM
92eg-pa's Avatar
Default Re: (Nikos)
thanks alot
Old Feb 5, 2007 | 06:14 PM
v4lu3s's Avatar
RTFM
the rocker assembly bolts in and out of the head though, the design has nothing in common with the way previous heads were designed. I do not see anything in that article that even addresses the fact that you will unbolt not just the cams, but also the rocker arms, rocker shafts and so on to remove the head.
All that article does is describe the engines and the technology, it does not address interchangeability in any way. I wish I could find the thread that I originally saw that discussed the possibility of interchanging the rocker assemblies. I suspect that the only diff between the head castings may be at most the machined boss to hold the LMA, and it may very well be that a machine shop can fix that easily.
Old Feb 5, 2007 | 07:09 PM
Nikos's Avatar
actually, you can only put the tsx rockers on a k20a3 head. On a k24a head, the rockers need to be trimmed, so it is no no..
A machine shop adding the holders for the LMA.... good luck with that.. I highly doubt it... If you really want to do something like this... just buy a new 2006 Civic Si head from honda.. bare head... cost is under $400.... If you have a friend that works for honda... much cheaper.
So, the CRV head has no lost motion assembly holders... the rockers will not fit 100%, and the valvetrain geometry is totally different from what I understand.
Old Feb 23, 2007 | 02:39 PM
ALL MOTOR EM2's Avatar
Default Re: (Nikos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nikos &raquo;</TD></TR><TR><TD CLASS="quote">actually, you can only put the tsx rockers on a k20a3 head. On a k24a head, the rockers need to be trimmed, so it is no no..
So, the CRV head has no lost motion assembly holders... the rockers will not fit 100%, and the valvetrain geometry is totally different from what I understand.</TD></TR></TABLE>
Take it from a K SERIES GURU
Old Feb 23, 2007 | 05:40 PM
92eg-pa's Avatar
Default Re: (ALL MOTOR EM2)
thanks alot guys, i actually just picked up a k20a2 for the swap. no worries now.
TravisBiggie
Sep 29, 2015 07:34 PM
lvsdan
Jun 25, 2014 08:28 PM
TravisRSX
Jan 15, 2014 01:27 PM
BaNAnABoAt689
Jun 2, 2004 11:05 PM
baonest
Jun 5, 2002 04:12 PM
