gsr swap question
Old Feb 8, 2007 | 05:58 AM
s2k4life2861's Avatar
Default gsr swap question
i just purchased a jdm gsr to swap into my ek i know i have to combine both the gsr and the ek harnesses will it work with the jdm gsr harness or do i need a usdm harness
Old Feb 8, 2007 | 08:12 AM
slomofo's Avatar
GDD Member
You can extend some wires on the JDM harness or plug a USDM harness right in.
Old Feb 8, 2007 | 10:34 AM
ekb16's Avatar
use your stock harness and search, its been covered ALOT of times
Modified by ekb16 at 11:44 AM 2/8/2007
Old Feb 9, 2007 | 06:14 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: (ekb16)
use your stock harness and run the wiring for the following:
-3 wire IACV to 2 wire
-IAB's
-VTEC solenoid and pressure switch wiring
-knock sensor wiring
-O2 extension harness
Actually the GSR motor prob won't have a VTEC pressure switch so you could just bypass this by grounding the signal wire unless you plan on using the JDM oBD2 GSR ecu
aznwash3wboi
Dec 22, 2008 02:23 PM
ColinSiR
May 11, 2008 12:19 PM
eknorcal
Nov 14, 2005 10:23 PM
