throttle cable B18c5 into EK
What throttle cable do I need for a B18c5 into 97 EK (CX)? Been searching and wound up with some conflicting answers. What is recommended? 99-00 SI or ITR throttle cable?
Re: throttle cable B18c5 into EK (12345)
innovative makes a bracket for the d series cable to use on the itr i think. but i have a b18cr in my 99 ek, and i just fliped the factory itr bracket 180 degrees so only one hole lines up and it works perfectly.
1. you can use your factorty cable if you get the innovative bracket : http://www.innovativemounts.co...59510
2. you can flip your factory ITR bracket 180 degrees and use the d-series cable (its free and it works fine)
3. you can get a ITR or 99-00 si cable (about 30 bucks)http://www.inlinefour.com/oemintypthro.html
BC_Garage
37
02-09-2016 08:46 PM
boostincoupe
02-17-2007 04:41 PM
vtec25
12-25-2006 02:53 PM
