NO VTEC
Old Feb 18, 2007 | 07:41 PM
Hatchman98's Avatar
Default NO VTEC
I have finished a swap and now i have no v-tec...? My speedometer is not working and the speed sensor is plugged in and snug. Any ideas what it could be?? Its a B16a obd1 JDM motor into a obd2 99EK hatch...with a obd2-1 conversion harness?
Old Feb 18, 2007 | 10:45 PM
RaceCarRyne's Avatar
Default Re: NO VTEC (Hatchman98)
too many factors.. wiring, oil pressure, vtec selonoid, pressure switch, any sensor that is needed to activate vtec. just start checking them one by one
Old Feb 19, 2007 | 11:49 AM
egsleepercivic's Avatar
was your speedometer working before, if so you prolly need a new VSS
Old Feb 20, 2007 | 06:39 PM
Hatchman98's Avatar
Default Re: (egsleepercivic)
well the guy that had the car b4 me had a gsr in it and the speedometer worked so ill try replacing the VSS... and see if that works.. thanks
Old Feb 20, 2007 | 07:03 PM
see if you can use the one off of your old motor
Old Feb 21, 2007 | 12:28 PM
Hatchman98's Avatar
the old motor is gone ... will a d-series one fit or should i stick with a GSR one??
Old Feb 21, 2007 | 02:55 PM
pennies_hatchie's Avatar
Default Re: (Hatchman98)
fix your vss and your vtak should work
Old Feb 22, 2007 | 09:04 AM
i don't know if d's work with B's it was just a suggestion before you go buy one, if you have a friend with a civic try swapping them out, then you will know for sure before you buy anything
Old Feb 22, 2007 | 11:17 AM
havok hybrid's Avatar
I have seen a fuse blew and the vss will not work.. .. check that also in the event a new vss doesnt work .
Old Feb 23, 2007 | 09:37 AM
Katman's Avatar
yes, a 92+ D-series VSS will work on a B-series engine.
ALso, what wire harness are you using for the swap and have you made necessary mods to it if its a non-vtec harness?
Old Feb 23, 2007 | 05:34 PM
Hatchman98's Avatar
Default Re: (Katman)
thanx guys the speed sensor works now and i got vtec... i put a new vss in and double checked all plugs...
TristanW10
Mar 15, 2010 03:33 PM
OBDII Integra
Oct 16, 2009 12:06 PM
skatr128
12
Apr 27, 2009 10:53 PM
JDM_SOHC
Nov 8, 2005 08:20 AM
civicseth
16
May 18, 2005 08:51 PM
