Crazy Cel Code 14 won't go away on EK/b18cR Swap (PLEASE HELP!!)
Finally Passed!!!
Basicly figured out that it was a temporary Cel that would mostly come on after the car was shut off and cut back on and run for a while. So, I just put the ecu in, ran the car on highway, and took it straight to emissions and bam... passed. Such a load off...
Modified by kay_animation at 7:36 AM 1/30/2007
Re: Crazy Cel Code 14 won't go away on EK/b18cR Swap (kay_animation)
it might just be caused by the ecu.. your prolly not wired right for the GSR.. ?? i dunno man.. I hope all goes well buddy..
Re: Crazy Cel Code 14 won't go away on EK/b18cR Swap (JJ-Built)
if incase you cant find out the problem in the next 2 days.. you can always renew the tags for MD... and then surrender it.. and get partial money back..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JJ-Built »</TD></TR><TR><TD CLASS="quote">if incase you cant find out the problem in the next 2 days.. you can always renew the tags for MD... and then surrender it.. and get partial money back.. </TD></TR></TABLE>
true true... wonder if I can run a 99-00 si ecu on a itr?
Re: Crazy Cel Code 14 won't go away on EK/b18cR Swap (ECAhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECAhatch »</TD></TR><TR><TD CLASS="quote">b u m p</TD></TR></TABLE>
Thanks there guy. I'm bringing you some cake
crvtt96
06-06-2004 04:00 PM
