code 16 after engine install
Old Mar 6, 2007 | 11:16 AM
civic2slo's Avatar
Default code 16 after engine install
I have a code 16 after a h22 went into a 96 civic. It coded up right when the key is switched on. I have checked the injectors. I have checked the wiring from the injector to the ecu and the injector wirings. Everything checks out. Theres power to the injectors. I guess the ecu is not sending a signal to pulse the injectors. What is the injector circut conneted to? What else should I check? Ecu is good I was also checked on another car.
SkIp_Civic_Ek6
Jan 17, 2007 07:37 PM
H22A EG6
Mar 31, 2005 07:53 PM
delux247
Jan 28, 2004 11:48 AM
pinoyboy204
Oct 9, 2003 04:57 PM
ahc'monracing
Sep 22, 2002 01:11 PM
