Evolution H2B in EG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White_Boy_Racing »</TD></TR><TR><TD CLASS="quote">thanks sal! ya jerk HAHA</TD></TR></TABLE>
Haha no problem.
Haha no problem.
Just an update on the swap. It is in the car and running. I am waiting on the alternator
braket and then the swap will be complete. I liked the way the kit went together for the most part. There were a few minor snags in the setup. The first was the rear T mount.
It did not mention in the kit on what T braket to use. I used a GSR mount.
If you look at the picture i posted I had to make an alumium spacer for the top bolt goin through the adapter plate. The second was the clutch slave cylinder. The spacer used in the kit seems to set the clutch slave to close to the clutch fork. I had to modify
the slave cylinder rod. I had to shorten it. (pics will be coming soon). Besides those two snags the kit went together nice. The only other issue I have is going to be oil changes. The drain plug is now at the highest point of the pan. And what about oil pick-up?? I have an idea of what i am goin to do with the pan but we will see how that turns out.
.....more to come
.....more to come
same, i did get my original one on there, forcefully, but the slave cyalnder soon F'd out
put new slave cylander on and then the clutch didnt release
shorter slave clylander rod fixed it tho
The clearance isnt that bad... lower than a bseries but nothing drastic. The main concern is how extreme the angle the oil pan is at. At this point oil starvation is the biggest issue. I think hes gonna modify the oil pan to sit level tho. Hopefully white_boy_racing will chime in with some pics of what im talking about.
