ls/vtec question
Old Feb 6, 2007 | 11:39 AM
btuned's Avatar
Default ls/vtec question
I was wondering if a itr crank,gsr rods,and p33 pistons is a good setup for a ls vtec with a b16a2 head
Old Feb 7, 2007 | 03:19 AM
gibsanez's Avatar
Default Re: ls/vtec question (btuned)
P33? What are your plans for this engine? Camz? You might want to search that crank combo, as i personally don't know if it fits. We do need some more details though.
Old Feb 7, 2007 | 06:37 PM
btuned's Avatar
Default Re: ls/vtec question (gibsanez)
by p33 i mean del sol si pistons,my plans is to build a reliable ls vtec that is still able to do 14's or so.i plan on using obx cams but i really not sure cuz i hear so many people talking bad about them. what is a reliable setup for an ls vtec ?
Old Feb 8, 2007 | 04:13 AM
gibsanez's Avatar
https://honda-tech.com/zerothread?id=1676914
http://www.zealautowerks.com/
and use this as a guide to choosing a pistons, as it still is a beta version. It will probably not give you absolutely exact numbers, but very close. And i think you mean PR3, not p33, if it's the usdm b16 you're talking about. Try searching for dyno threads and whatnot, as I've heard good things about the RM lineup, Buddy club, and Skunk2 camz. I know for sure that if you pm cleanrice he can give you a buttload of info on the rm camz.
Old Feb 8, 2007 | 01:30 PM
btuned's Avatar
i appreciate all the info, i do mean pr3 pistons,i got the golden eagle conversion kit for an ls vtec,i have done a lot of research about ls vtecs but no one has done the bottom end like i did, i have heard people say that the itr crank destrokes the engine by like 37cc, i have had engine running and lacks power,it had low compression on the #3 cylinder so i took the head off and i had bad valve seat so i had that fix and now it is still lacks power.what is amount of compression does a ls vtec supposed to have?
Old Feb 8, 2007 | 06:37 PM
gibsanez's Avatar
Yes, the crank has a shorter throw and will destroke the engine a little bit. I'm not sure what exact compression numbers you should have, but i bet you can look it up in a haynes or chilton manual or whatev.
Old Feb 11, 2007 | 07:58 AM
killerpenguin21's Avatar
do some research...its not ls/vtec without las crank and rods.
Sergio Garcia
Aug 30, 2015 08:35 AM
jaydmej1
Jan 27, 2004 08:04 AM
mrbsponge
Jan 6, 2004 12:11 PM
B18G
Sep 21, 2003 10:51 PM
