please help me! swapped b18c !!
Old Feb 19, 2007 | 09:27 PM
B series FTW's Avatar
Default please help me! swapped b18c !!
just swapped in a jdm b18c into a civic ex and when i came to start the car up the first time it cranked/sparked, but it didn't start up and blew out **** load of smoke from the exhaust since there was oil in the cylinders during compression test. now the car only cranks, but it doesnt spark. the previous shop i purchased the motor from put oil inside the cylinders for a compression test so could the spark plugs be covered up in oil or could it be the coil inside the distributor? any other suggestions???!!!! also when i was cranking the car up some of the intake manifold vacuum lines were not plugged in could that be another issue lol ?
HELP!!
Here are some pictures during the process.
Now this bitch needs to start up!
Old Feb 19, 2007 | 09:38 PM
Default Re: please help me! swapped b18c !! (B series FTW)
Old Feb 20, 2007 | 10:18 AM
blu3g's Avatar
you probably fried the coil or rotor during the compression test. did you take the spark plug wires off the dizzy side during compression test?
jdmwarrior
13
Jan 30, 2013 08:30 PM
LS93B18C
May 21, 2006 02:39 PM
GSR4door1
Mar 31, 2004 06:39 PM
Blazin Si
May 20, 2003 06:52 AM
wu tang
18
Oct 2, 2002 09:25 PM
