Type R LSD & Final Drive Swap
I heard that if i get the ITR LSD and FD I can swap that onto my B18B tranny. Is that true? Is there any other Honda LSD that will directly bolt up to my B18B trans?
Re: Type R LSD & Final Drive Swap (Big Teggie)
can i use a stock jdm si or gsr lsd? will those bolt right up without the final drive and stuff?
Re: Type R LSD & Final Drive Swap (AlienKrOZ)
are the 92-93 gsr LSD a direct bolt up to the 94-01 integra LS/RS/GS? i see that quaife has the same part number on them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Teggie »</TD></TR><TR><TD CLASS="quote">It will swap right in if you have the ITR LSD, countershaft and ring gear. </TD></TR></TABLE>
so if i get the ITR LSD, countershaft, ring gear, and FD everything should go in my B18B LS tranny no problem?
