mounts needed for b into eg & auto to manual
i searched and ive heard two different things
1. you need these three integra chasis mount parts w/o the rubber
https://honda-tech.com/zerothread?id=351514
2. you only need the one rear whole integra mount
i already purchased the auto - manual innovative mount
what else will i need exactly?
I'm really 2slow
Re: mounts needed for b into eg & auto to manual (dafuzzbudd)
you will need the 5 speed pedal assembly from a 92-95 civic along with the clutch master and slave cylinders. clutch reservoir and clutch hardlines
what else do you have right now?
Re: mounts needed for b into eg & auto to manual (2FAST4U831)
yea im straight with the auto-manual stuff
im getting the b axles + b shift linkage
i think im going to need a manual b throttle cable + manual b starter
hm.. note taken
are the intake manifold different between auto & manual b?
Is the engine from an auto or just your car now?
If the engine started as an auto, some have weaker cams from auto's. The H22 and the old 3 g accords were like that.
Markis.
01-05-2005 10:33 AM
